I re-added the source and everything, it shows its finding the movies and tv shows in the scanning new content dialog in the upper right, but it never shows in Movies or TV Shows menu, I can navigate to the files just fine through videos, but they seem to not be scraping. Has something changed? Using TheMovieDB and TVDB
Thanks, I think the debug log definitely helped. Noticed this one line in the list of errors that led me to believe it was a corrupt database:
"ERROR: SQL: [MyVideos99.db] The database disk image is malformed"
Backed up and cleared the database files for MyVideos##.db and TV.db, so far its working fine.
Thanks for the idea, hopefully this helps someone with the same question further.
Happened to me after my power went out while using Kodi. It was completely fried and due to a lack of a backup, starting from scratch was my only option.
I'm having the same issue. Can someone direct me to where the corrupt files are stored in OS X?
