Full Version: Kodi creating bad images - Help needed
Hi everyone..
I'm building using Phenomenal on an Android TV box.
Phenomenal is a great skin, but for some reason, when I use a multi-image as background, it duplicates the images that I'm using. If I use single image it does not do this.
Huh
Anyone got any ideas as to why it may be doing this? Any suggestions to fix this?
Just to let everyone know, I've solved the problem...
If you point Kodi to an image folder that is outside it's directory, then it creates strange copies of the images.
Best is to create a holder inside the .Kodi folder. I named it Bckgrnds, and inside that named the folders again with subdirectories.
Haven't had a problem since then.
Hopefully this helps someone Wink
