Full Version: Apple TV 4: re-signing Kodi question
I am about to re-sign the Kodi .ipa after the app expired due to my using a free developer account. Can someone confirm the steps I'm going to take?
In iOS app signer, for the input file I'll browse to the same .deb file I used before. For the provisioning profile I'll select the same output file from Xcode I used last time. After pressing Start I'll allow it to overwrite my prior .ipa file.
Then in Xcode I'll remove the Kodi app from my apple TV 4 (is removing it necessary?) and add the new .ipa file.
If I'm missing something or there's a better way, any help will be greatly appreciated.
No need to remove the old ipa from your ATV first, just replace it over the existing one.
I ran into a problem. After the signing certificate expired I opened iOS app signer to re-sign the app. I chose the .deb file as the input file, but my earlier provisioning profile wasn't in the dropdown. I chose 'choose custom file', but when I navigate to the folder I used last time I can't select the folder... it keeps opening folders to get to the file level.
Any ideas how I can populate the the provisioning profile window in ios app signer with my original profile?
