I'm running Windows 7 and did fresh start Kodi 16.1 When I select a music station from Radio addon the music starts, screen shows opening music stream then Kodi crashes. Is there something I should be tweaking?
Gonna need a
debug log (wiki) for that I would think.
Going to move this to the music addons forum where may get more support
I have the same freezing problem on Arch linux (x86-64) with default PAPLAYER and DVDPLAYER. If I create file advancedsettings.xml with '..<defaultplayer>ffplay</defaultplayer>..' and file playercorefactory.xml with '..<player name="ffplay" type="ExternalPlayer" audio="true" video="false"><filename>/usr/bin/ffplay</filename></player>..' then Kodi not crashes.
...but it is impractical.
Example problems with
http://icecast8.play.cz/cro1-128.mp3
Provide a link to your FULL debug log.
My debug log without advancedsettings.xml and without playercorefactory.xml:
http://pastebin.com/h1zWzPfi
22:59:01 started 'Radio' station (cro1-128.mp3.m3u) = freeze Kodi
23:05:01 I disconnected LAN
23:06:24 unfreeze Kodi (LAN still disconnected, but Kodi started playing music from buffer)
23:12:34 stop music
23:13:44 close Kodi
I have same problem in Kodi v16.
I have same problem in Kodi v17, LibreElec 7.90.010. Device is Asrock Beebox N3000.
Can you confirm, please, if it works for you?
1.) Music addon > Radio (version 2.3.1, Autor Tristan Fischer) > Browse by country > Czech Republic > Czech Radio 1 - Radio Journal (fifth from top)
or
2.)
http://icecast8.play.cz/cro1-128.mp3 (eg. using an .strm file)
Thank you.
I've installed stable version LE 7.0.3 on a Asrock Beebox and it works well.
I do not know what was wrong on LE 7.90.010 and Archlinux Kodi v16. :-(
(2017-01-28, 12:28)novicior Wrote: [ -> ]I've installed stable version LE 7.0.3 on a Asrock Beebox and it works well.
This is a known issue. See
this
