Hi!
I want to create an addon, where I can select multiple files.
I already tried using xbmcgui.Dialog().browseMultiple with no luck.
My code:
PHP Code:
dialog = xbmcgui.Dialog()
files = dialog.browseMultiple(1, 'Select files', 'files')
The documentation says: "returns tuple of marked filenames as a string"
It returns a tuple, but i can't mark multiple files, only select one.
I'm using Krypton Beta 5, it neither works in Jarvis.
What am I doing wrong? Is this even possible with Kodi the addon API?
Thanks for the replies!
well, it does work... if you can figure out how to :-)
when you want to select multiple items, you need to do so by pressing the space bar on your keyboard.
i have to admit, this is far from intuitive (and it's not even possible to do this with a remote control).
everywhere else in kodi where multiselect is applicable, you can simply click on items to select them.
(2016-11-29, 19:31)ronie Wrote: [ -> ]well, it does work... if you can figure out how to :-)
You could build a simple method for simple multi select. Basically you would select every item a user clicks on and only deselect when the click on it again. Keep an internal map of selected indexes. If you are familiar with extjs they have a similar method set using a trigger. Would be a nice feature in kodi for those that do not use keyboards.
Thank you very much!
It's working now.
I'll maybe use a hack to make it rc compatible, until it gets fixed in the core.
(2016-11-29, 19:36)Protocol-X Wrote: [ -> ] (2016-11-29, 19:31)ronie Wrote: [ -> ]well, it does work... if you can figure out how to :-)
You mean, it should be implemented in the core, not in my addon, right?
(2016-11-29, 22:43)ata2001 Wrote: [ -> ] (2016-11-29, 19:36)Protocol-X Wrote: [ -> ] (2016-11-29, 19:31)ronie Wrote: [ -> ]well, it does work... if you can figure out how to :-)
Well the best solution would be the core, but you could always build something custom. Core is always preferable as user would have the same feature in all addons I have had to build a few custom solutions due to Limitations and it is not always the best solution. But glad to see Ronie has a solution coming your way
