I reinstalled the WinXP with Mediaportal 1.4 - still no connection. Of course I am glad if someone might take a look into the log-file, but I fear the problem is on the server side:
12:45:10 T:140695646098944 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:45:10 T:140695646098944 NOTICE: -----------------------------------------------------------------------
12:45:10 T:140695646098944 NOTICE: Starting Kodi (16.1 Git:Unknown). Platform: Linux x86 64-bit
12:45:10 T:140695646098944 NOTICE: Using Release Kodi x64 build
12:45:10 T:140695646098944 NOTICE: Kodi compiled Nov 13 2016 by GCC 6.2.1 for Linux x86 64-bit version 4.7.0 (263936)
12:45:10 T:140695646098944 NOTICE: Running on Arch Linux 0.0, kernel: Linux x86 64-bit version 4.8.11-1-ARCH
12:45:10 T:140695646098944 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
12:45:10 T:140695646098944 NOTICE: Host CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+, 2 cores available
12:45:10 T:140695646098944 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
12:45:10 T:140695646098944 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
12:45:10 T:140695646098944 NOTICE: special://masterprofile/ is mapped to: /home/bernd_b/.kodi/userdata
12:45:10 T:140695646098944 NOTICE: special://home/ is mapped to: /home/bernd_b/.kodi
12:45:10 T:140695646098944 NOTICE: special://temp/ is mapped to: /home/bernd_b/.kodi/temp
12:45:10 T:140695646098944 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
12:45:10 T:140695646098944 NOTICE: Local hostname: amd64-archlinux
12:45:10 T:140695646098944 NOTICE: Log File is located: /home/bernd_b/.kodi/temp/kodi.log
12:45:10 T:140695646098944 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanSuspend'
12:45:10 T:140695646098944 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanHibernate'
12:45:10 T:140695646098944 NOTICE: load settings...
12:45:10 T:140695646098944 NOTICE: Found 1 Lists of Devices
12:45:10 T:140695646098944 NOTICE: Enumerated PULSE devices:
12:45:10 T:140695646098944 NOTICE: Device 1
12:45:10 T:140695646098944 NOTICE: m_deviceName : Default
12:45:10 T:140695646098944 NOTICE: m_displayName : Default
12:45:10 T:140695646098944 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
12:45:10 T:140695646098944 NOTICE: m_deviceType : AE_DEVTYPE_PCM
12:45:10 T:140695646098944 NOTICE: m_channels : FL,FR
12:45:10 T:140695646098944 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
12:45:10 T:140695646098944 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
12:45:10 T:140695646098944 NOTICE: Device 2
12:45:10 T:140695646098944 NOTICE: m_deviceName : alsa_output.pci-0000_00_14.2.analog-stereo
12:45:10 T:140695646098944 NOTICE: m_displayName : Built-in Audio Analog Stereo
12:45:10 T:140695646098944 NOTICE: m_displayNameExtra: Line Out (PULSEAUDIO)
12:45:10 T:140695646098944 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:45:10 T:140695646098944 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:45:10 T:140695646098944 NOTICE: Default DVD Player: dvdplayer
12:45:10 T:140695646098944 NOTICE: Default Video Player: dvdplayer
12:45:10 T:140695646098944 NOTICE: Default Audio Player: paplayer
12:45:10 T:140695646098944 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:45:10 T:140695646098944 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
12:45:10 T:140695646098944 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:45:10 T:140695646098944 NOTICE: Loaded playercorefactory configuration
12:45:10 T:140695646098944 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:45:10 T:140695646098944 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:45:10 T:140695211775744 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
11:45:10 T:140695646098944 NOTICE: Running database version Addons20
11:45:10 T:140695646098944 NOTICE: ADDONS: Using repository repository.xbmc.org
11:45:10 T:140695646098944 NOTICE: Setup SDL
11:45:10 T:140695646098944 WARNING: CXRandR::Query - output VGA-0 has no current mode, assuming disconnected
11:45:10 T:140695646098944 NOTICE: Checking resolution 15
11:45:10 T:140695646098944 NOTICE: Using visual 0x28
11:45:10 T:140695646098944 NOTICE: GL_VENDOR = NVIDIA Corporation
11:45:10 T:140695646098944 NOTICE: GL_RENDERER = GeForce 210/PCIe/SSE2
11:45:10 T:140695646098944 NOTICE: GL_VERSION = 3.3.0 NVIDIA 340.98
11:45:10 T:140695646098944 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
11:45:10 T:140695646098944 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 1048576
11:45:10 T:140695646098944 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 1048576
11:45:10 T:140695646098944 NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_
compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
11:45:10 T:140695646098944 ERROR: Unable to load libcec.so.4, reason: libcec.so.4: cannot open shared object file: No such file or directory
11:45:10 T:140695646098944 ERROR: Initialise - failed to initialise bus cec
11:45:10 T:140695646098944 NOTICE: Running database version ViewModes6
11:45:10 T:140695646098944 NOTICE: Running database version Textures13
11:45:10 T:140695646098944 NOTICE: Running database version MyMusic56
11:45:10 T:140695646098944 NOTICE: Running database version MyVideos99
11:45:10 T:140695646098944 NOTICE: Running database version TV29
11:45:10 T:140695646098944 NOTICE: Running database version Epg11
11:45:10 T:140695646098944 NOTICE: start dvd mediatype detection
11:45:11 T:140695646098944 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:45:11 T:140695646098944 NOTICE: ActiveAE DSP - starting
11:45:11 T:140695646098944 NOTICE: initialize done
11:45:11 T:140695646098944 NOTICE: Running the application...
11:45:11 T:140695103178496 NOTICE: PVRManager - starting up
11:45:11 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:45:11 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:45:11 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:45:11 T:140694740002560 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:45:11 T:140694740002560 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:45:11 T:140695646098944 NOTICE: starting zeroconf publishing
11:45:11 T:140695646098944 NOTICE: starting upnp client
11:45:11 T:140694060525312 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
11:45:11 T:140694060525312 NOTICE: UDP: Listening on port 9777
11:45:16 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:45:16 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:45:16 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:45:16 T:140694740002560 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:45:16 T:140694740002560 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:45:21 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:45:21 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:45:21 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:45:21 T:140694740002560 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:45:21 T:140694740002560 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:45:26 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:45:26 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:45:26 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:45:26 T:140694740002560 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:45:26 T:140694740002560 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:45:31 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:45:31 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:45:31 T:140694740002560 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:45:31 T:140694740002560 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:45:31 T:140694740002560 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:46:14 T:140695646098944 NOTICE: PVRManager - stopping
11:46:17 T:140695103178496 NOTICE: PVRManager - starting up
11:46:17 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:46:17 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:46:17 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:46:17 T:140695086393088 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:46:17 T:140695086393088 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:46:22 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:46:22 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:46:22 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:46:22 T:140695086393088 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:46:22 T:140695086393088 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:46:27 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.0.101:9596
11:46:27 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (errno=111) ECONNREFUSED: A remote host refused to allow the network connection (typically because it is not running the requested service)
11:46:27 T:140695086393088 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:46:27 T:140695086393088 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:46:27 T:140695086393088 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:46:31 T:140695646098944 NOTICE: Storing total System Uptime
11:46:31 T:140695646098944 NOTICE: Saving settings
11:46:31 T:140695646098944 NOTICE: stop all
11:46:31 T:140695646098944 NOTICE: stop player
11:46:31 T:140695646098944 NOTICE: PVRManager - stopping
11:46:31 T:140695646098944 NOTICE: ES: Stopping event server
11:46:31 T:140695646098944 NOTICE: stopping upnp
11:46:31 T:140695646098944 NOTICE: stopping zeroconf publishing
11:46:31 T:140694060525312 NOTICE: ES: UDP Event server stopped
11:46:31 T:140695646098944 NOTICE: stop dvd detect media
11:46:32 T:140695646098944 NOTICE: stop sap announcement listener
11:46:32 T:140695646098944 NOTICE: clean cached files!
11:46:32 T:140695646098944 NOTICE: unload skin
11:46:32 T:140695646098944 NOTICE: stopped
11:46:32 T:140695646098944 NOTICE: destroy
11:46:32 T:140695646098944 NOTICE: closing down remote control service
11:46:32 T:140695646098944 NOTICE: unload sections
11:46:32 T:140695646098944 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:46:32 T:140695646098944 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:46:32 T:140695646098944 NOTICE: application stopped...
