Full Version: Attempting to add Chorus 2 getting "Addon does not have the correct structure"
Trying https://github.com/xbmc/chorus2/releases this URL which I assume is correctly structured.
No you need to to download the zip file
Thread moved to the correct sub forum
(2016-12-13, 13:46)Martijn Wrote: [ -> ]No you need to to download the zip file
I have. File name: 'webinterface.default.2.3.6.zip'
I have tried manually installing that on a few different devices and it worked. Did you "Install as zip" in kodi?
(2016-12-14, 02:56)jez500 Wrote: [ -> ]I have tried manually installing that on a few different devices and it worked. Did you "Install as zip" in kodi?
Yes.
Anyone?
Hard to tell without a debug log (wiki) of you trying to install it.
However, I do know that due to some bug in Kodi, if any add-on fails to install then any subsequent attempt to install it (even if the structure issue has been resolved) will not work until Kodi is re-started.
