can you please share the information how can I install this add on. Thank you.
would be nice to have those in our addon repo ::hint:: ::hint::
You need skin support use resource images addon, like MQ7 used images in the first post. Go to settings, addons, install via zip file. After go to settings, skin settings, icons & images, select icon weather, and choose WeatherIconsCloudAnimated.
+1 for put in official repo.
Thank you Wanilton...
As the repo I would love but do not know what I should do...
(2017-01-11, 19:17)ronie Wrote: [ -> ]it's as easy as creating a new issue here:
https://github.com/xbmc/repo-resources/issues
you'd need to provide a link where we can get the addon with the source images instead of the Textures.xbt file.
OK I have to close for today I will try to have a look tomorrow, bye bye
___________________________________________________________
Hello this morning i created an issue, i hope that you have not screwed up.
(2017-01-10, 20:51)Wanilton Wrote: [ -> ]You need skin support use resource images addon, like MQ7 used images in the first post. Go to settings, addons, install via zip file. After go to settings, skin settings, icons & images, select icon weather, and choose WeatherIconsCloudAnimated.
Thanks for the tutorial. successfully installed.
Your Textures.xbt is not correctly packed, icons with clouds are full white. When I unpack them it's ok.
Same on git and kodi repo.
