2016-12-30, 16:23
2017-01-03, 08:24
will probably not happen in this version because you use a smaller screen than we defined as the smallest size for layouting.
2017-01-12, 21:48
Many thanks mlaggner,
Sorry, which version is meant by "this version"? And what will not be happen, sorry again?
Hmmm, I am not quite sure, my common 15,6 display too small, obviously? Do I understand it right?
Is there anything I could do to correct it?
Many thanks again
Many thanks again
2017-01-13, 08:25
your resolution might be too low (the screen size of 15,6" is not relevant)..
we designed tmm with a minimal resolution of 1366x768 (minus the windows taskbar height) in mind.
If you have anything different (lower screen resolution, bigger windows task bar, bigger window borders), there might be not enough space for tmm..
we do a general ui overhaul where another layoutmanager is used (which works better imho), so I will not put any energy in re-layouting version 2 at the moment.
2017-01-13, 09:46
Alright, great, thank you very much
