Full Version: No wakeup for "multiday" recordings
Hi there,
Not sure if this is a kodi.pvr.vnsi problem or a general kodi problem, I thought I'd try it here first.
I've set up the Kodi power save option running /usr/bin/setwakeup.sh before shutdown. For normal recordings this works like a charm, the htpc wakes up, records, goes to sleep.
I do have some recordings that run every Monday and Friday though where the htpc refuses to wake. Format in timers.conf is this:
1:C-1-101-1:M---F--:0553:0628:1:1:test:
cat /usr/bin/setwakeup.sh
#!/bin/sh
sudo sh -c "echo 0 > /sys/class/rtc/rtc0/wakealarm"
sudo sh -c "echo $1 > /sys/class/rtc/rtc0/wakealarm"
These timers are not shown in the "TV/Timers" in kodi itself so I guess that is most likely the problem, anything I can do about this?
This problem was introduces some time back with the new timer api.
Let me check if I can get this fixed with a small change to vnsi.
will be fixed by https://github.com/kodi-pvr/pvr.vdr.vnsi/pull/99
repeating timer will be visible as timer rule
vnsi wil create 2 child timers from this rule, this allows kodi to schedule a wake-up
That did make it work indeed, timer now shows up in "Timer Rules" thanks for the quick fix! Smile
