Full Version: Problems with files over 4gb using smb mount
not sure whats up, but I'm mounting a samba share (suse) on ubuntu (xbmc). I can copy files over 4gb e.g. matroska or dvd iso's to my local disc using the mounts and then play them fine using xbmc, but when I try to play them over the network (via the mount point) the matroska files don't play at all and dvd iso play till they reach the 4 gb point and then stop.
Guess my next step is NFS, but I know that the server works with those files using smb and my old xbox xbmc
anyone out there having the same problem ?
madmax
ok, using NFS from the same server same share works with XBMC...
Which leaves the questions why would 4gig+ files not work on XBMC(linux) but work fine using XBMC (xbox) ??
22:07:33 T:3060885344 M:441307136 DEBUG: OnKey: 11 pressed, action is 7
22:07:33 T:3060885344 M:441237504 DEBUG: CPlayerCoreFactor::GetPlayers(/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv)
22:07:33 T:3060885344 M:441237504 NOTICE: DVDPlayer: Opening: /home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv
22:07:33 T:3060885344 M:441237504 NOTICE: CDVDPlayer::CloseFile()
22:07:33 T:3060885344 M:441237504 WARNING: CDVDMessageQueue:Tongueut MSGQ_NOT_INITIALIZED
22:07:33 T:3060885344 M:441237504 NOTICE: DVDPlayer: waiting for threads to exit
22:07:33 T:3060885344 M:441237504 NOTICE: DVDPlayer: finished waiting
22:07:33 T:2956974992 M:441237504 DEBUG: Running thread 2956974992
22:07:33 T:2956974992 M:441237504 DEBUG: thread start, auto delete: 0
22:07:33 T:2956974992 M:441237504 NOTICE: Creating InputStream
22:07:33 T:2956974992 M:441237504 NOTICE: Creating Demuxer
22:07:33 T:2956974992 M:441237504 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avutil-51-i486-linux.so
22:07:33 T:2956974992 M:441237504 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avcodec-51-i486-linux.so
22:07:33 T:2956974992 M:438661120 DEBUG: DllAvCodec loaded
22:07:33 T:2956974992 M:438661120 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avformat-51-i486-linux.so
22:07:33 T:2956974992 M:437964800 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x1549a966
22:07:33 T:2956974992 M:437964800 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x1654ae6b
22:07:33 T:2956974992 M:437964800 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x114d9b74
22:07:33 T:2956974992 M:437895168 INFO: ffmpeg: [matroska] Unknown entry 0x73a4 in info header
22:07:33 T:2956974992 M:437895168 INFO: ffmpeg: [matroska] Unknown track header entry 0x55aa - ignoring
22:07:33 T:2956974992 M:437895168 INFO: ffmpeg: [matroska] Unknown track header entry 0x23314f - ignoring
22:07:33 T:2956974992 M:437895168 INFO: ffmpeg: [matroska] Unknown track header entry 0x55ee - ignoring
22:07:33 T:2956974992 M:437895168 INFO: ffmpeg: [matroska] Unknown track header entry 0xaa - ignoring
22:07:33 T:2956974992 M:436224000 INFO: ffmpeg: Input #0, matroska, from '/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv':
22:07:33 T:2956974992 M:436224000 INFO: ffmpeg: Duration: 01:29:30.8, start: 0.000000, bitrate: N/A
22:07:33 T:2956974992 M:436224000 INFO: ffmpeg: Stream #0.0(eng): Subtitle: 0x0000
22:07:33 T:2956974992 M:436224000 INFO: ffmpeg: Stream #0.1(eng): Audio: ac3, 48000 Hz, 5:1
22:07:33 T:2956974992 M:436224000 INFO: ffmpeg: Stream #0.2(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 tb®
22:07:33 T:2956974992 M:436224000 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: START
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: Checking for common subirs...
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: Done (time: 2 ms)
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: Searching for subtitles...
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: Done (time: 4 ms)
22:07:33 T:2956974992 M:436224000 DEBUG: CacheSubtitles: END (total time: 7 ms)
22:07:33 T:2956974992 M:436224000 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done
22:07:33 T:2956974992 M:436224000 NOTICE: Opening audio stream: 1
22:07:33 T:2956974992 M:436224000 NOTICE: Finding audio codec for: 86020
22:07:33 T:2956974992 M:436224000 DEBUG: FactoryCodec - Audio: passthrough - Opening
22:07:33 T:2956974992 M:436224000 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/libdts-i486-linux.so
22:07:33 T:2956974992 M:436224000 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/liba52-i486-linux.so
22:07:33 T:2956974992 M:436224000 DEBUG: FactoryCodec - Audio: passthrough - Opened
22:07:33 T:2956974992 M:436224000 NOTICE: Creating audio thread
22:07:33 T:2948582288 M:436224000 DEBUG: Running thread 2948582288
22:07:33 T:2948582288 M:436224000 DEBUG: thread start, auto delete: 0
22:07:33 T:2948582288 M:436224000 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
22:07:33 T:2956974992 M:436224000 NOTICE: Opening video stream: 2
22:07:33 T:2956974992 M:436224000 NOTICE: Creating video codec with codec id: 28
22:07:33 T:2956974992 M:436224000 DEBUG: FactoryCodec - Video: FFmpeg - Opening
22:07:33 T:2956974992 M:436224000 DEBUG: DllAvCodec loaded
22:07:33 T:2956974992 M:436224000 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/swscale-51-i486-linux.so
22:07:33 T:2956974992 M:436224000 DEBUG: FactoryCodec - Video: FFmpeg - Opened
22:07:33 T:2956974992 M:436224000 NOTICE: Creating video thread
22:07:33 T:2956974992 M:436224000 DEBUG: Playback has started
22:07:33 T:2948582288 M:435806208 DEBUG: CDVDAudioCodecPassthrough: Synced to AC3 frame
22:07:33 T:2948582288 M:435806208 NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, pass-through
22:07:33 T:2948582288 M:435806208 DEBUG: CALSADirectSound::CALSADirectSound - opening alsa device
22:07:33 T:2965367696 M:435666944 DEBUG: Running thread 2965367696
22:07:33 T:2965367696 M:435666944 DEBUG: thread start, auto delete: 0
22:07:33 T:2965367696 M:435666944 DEBUG: Constructing surface
22:07:33 T:2965367696 M:435666944 INFO: GLX Info: Using destination window
22:07:33 T:2948582288 M:435666944 DEBUG: CDVDPlayerAudio:: Resync - clock:0.000000, delay:7999.999106
22:07:33 T:2965367696 M:435666944 INFO: GLX Info: Creating shared context
22:07:33 T:2965367696 M:431177728 INFO: GL: OpenGL version 2.1 detected
22:07:33 T:2965367696 M:431177728 INFO: GL: NPOT textures are supported natively
22:07:33 T:2965367696 M:431177728 DEBUG: DllAvCodec loaded
22:07:33 T:2965367696 M:430759936 NOTICE: GL: Selecting YUV 2 RGB Progressive Shader
22:07:33 T:2965367696 M:430268416 DEBUG: GL: Shader compilation log:
22:07:33 T:2965367696 M:430268416 NOTICE: running thread: video_thread
22:07:33 T:3060885344 M:429363200 INFO: Loading skin file: VideoOverlay.xml
22:07:33 T:3060885344 M:429363200 DEBUG: Load VideoOverlay.xml: 2.97ms (1.15 ms xml load)
22:07:33 T:3060885344 M:429363200 DEBUG: Alloc resources: 3.15ms (3.14 ms skin load, 0.01 ms preload)
22:07:33 T:2965367696 M:429363200 NOTICE: fps: 23.975986, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
22:07:33 T:2965367696 M:429363200 DEBUG: OutputPicture- change configuration. 1280x720. framerate: 23.98
22:07:33 T:2965367696 M:429363200 NOTICE: Display resolution USER : 1280x720 (Desktop) (12)
22:07:33 T:2965367696 M:429363200 INFO: GL: OpenGL version 2.1 detected
22:07:33 T:2965367696 M:429363200 INFO: GL: NPOT textures are supported natively
22:07:33 T:2965367696 M:429363200 DEBUG: GL: Creating Y NPOT texture of size 1280 x 720
22:07:33 T:3060885344 M:429363200 DEBUG: CGUIInfoManager::SetCurrentMovie(/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv)
22:07:33 T:2965367696 M:429363200 DEBUG: GL: Creating U NPOT texture of size 640 x 360
22:07:33 T:2965367696 M:429363200 DEBUG: GL: Creating V NPOT texture of size 640 x 360
22:07:33 T:2965367696 M:429363200 DEBUG: GL: Creating U NPOT texture of size 640 x 180
22:07:33 T:2965367696 M:429363200 DEBUG: GL: Creating V NPOT texture of size 640 x 180
22:07:33 T:3060885344 M:429363200 DEBUG: CVideoDatabase::GetMovieInfo(/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv), query = select idMovie from movie where idFile=154
22:07:33 T:3060885344 M:429363200 DEBUG: CVideoDatabase::GetEpisodeInfo(/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv), query = select idEpisode from episode where idFile=154
22:07:33 T:3060885344 M:429363200 DEBUG: CVideoDatabase::GetMusicVideoInfo(/home/xbmc/NFS/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv), query = select idMVideo from musicvideo where idFile=154
22:06:35 T:3060885344 M:463921152 DEBUG: OnKey: 11 pressed, action is 7
22:06:35 T:3060885344 M:463921152 DEBUG: CPlayerCoreFactor::GetPlayers(/home/xbmc/SMB/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv)
22:06:35 T:3060885344 M:463921152 NOTICE: DVDPlayer: Opening: /home/xbmc/SMB/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv
22:06:35 T:3060885344 M:463921152 NOTICE: CDVDPlayer::CloseFile()
22:06:35 T:3060885344 M:463921152 WARNING: CDVDMessageQueue:Tongueut MSGQ_NOT_INITIALIZED
22:06:35 T:3060885344 M:463921152 NOTICE: DVDPlayer: waiting for threads to exit
22:06:35 T:3060885344 M:463921152 NOTICE: DVDPlayer: finished waiting
22:06:35 T:2956974992 M:463851520 DEBUG: Running thread 2956974992
22:06:35 T:2956974992 M:463851520 DEBUG: thread start, auto delete: 0
22:06:35 T:2956974992 M:463851520 NOTICE: Creating InputStream
22:06:35 T:2956974992 M:463851520 NOTICE: Creating Demuxer
22:06:35 T:2956974992 M:463851520 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avutil-51-i486-linux.so
22:06:35 T:2956974992 M:463851520 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avcodec-51-i486-linux.so
22:06:35 T:2956974992 M:461066240 DEBUG: DllAvCodec loaded
22:06:35 T:2956974992 M:461066240 DEBUG: Loading: /home/xbmc/XBMC/BUILD/system/players/dvdplayer/avformat-51-i486-linux.so
22:06:35 T:2956974992 M:460509184 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x1549a966
22:06:35 T:2956974992 M:460509184 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x1654ae6b
22:06:35 T:2956974992 M:460509184 INFO: ffmpeg: [matroska] Ignoring seekhead entry for ID=0x114d9b74
22:06:35 T:2956974992 M:460509184 ERROR: Process - Error opening demuxer
22:06:35 T:2956974992 M:460509184 NOTICE: CDVDPlayer::OnExit()
22:06:35 T:2956974992 M:460509184 NOTICE: DVDPlayer: eof, waiting for queues to empty
22:06:35 T:2956974992 M:460509184 NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:06:35 T:2956974992 M:460509184 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:06:35 T:2956974992 M:460509184 DEBUG: Playback has finished
22:06:35 T:2956974992 M:460509184 DEBUG: staticThread, deleting thread graphic context
22:06:35 T:2956974992 M:460509184 DEBUG: Thread 2956974992 terminating
22:06:36 T:3060885344 M:460566528 WARNING: CDVDMessageQueue:Tongueut MSGQ_NOT_INITIALIZED
22:06:36 T:3060885344 M:460431360 DEBUG: CVideoDatabase::GetEpisodeInfo(/home/xbmc/SMB/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv), query = select idEpisode from episode where idFile=153
22:06:36 T:3060885344 M:460431360 DEBUG: CVideoDatabase::GetMusicVideoInfo(/home/xbmc/SMB/tv/Battlestar Galactica/Battlestar.Galactica.Miniseries.2003.Part.2.720p.HDDVD.x264-SiNNERS.mkv), query = select idMVideo from musicvideo where idFile=153
22:06:36 T:3060885344 M:460431360 NOTICE: CDVDPlayer::CloseFile()
22:06:36 T:3060885344 M:460431360 WARNING: CDVDMessageQueue:Tongueut MSGQ_NOT_INITIALIZED
22:06:36 T:3060885344 M:460431360 NOTICE: DVDPlayer: waiting for threads to exit
22:06:36 T:3060885344 M:460431360 NOTICE: DVDPlayer: finished waiting
22:06:36 T:3060885344 M:460431360 DEBUG: clear
just out of curiosity have you tried using xbmc samba client instad of mounting them in linux ?
hmm, point taken...
will try tomorrow.....to late now :-)
You might have hit some sort of 32-bit limit (2^32=4GB).
ok, guess all the noise for almost nothing...
the build-in smb stuff works...
still have no glue why mounting a share using ubuntu via smb would bring up a 4gb problem, but thats what happens...
guess this thread can be closed...
thanks for listening...
madmax
