Full Version: NextPVR Live TV Slowmotion - Android
Hello,
I currently have an android TV device with both KODI 17 RC and the SPMC (fork version of KODI 16) installed.
Issue is happening on KODI 17, no on KODI 16 or the fork version based on KODI 16. The issue does not occur on the server neither.
I noticed that when switching channels, some HD channels stay in slow motion. I keep the channel on, but it doesnt change or fix itself. If I switch channels and go back, it sometimes fixes itself. No specific channel, happens to any HD channel at random.
All versions of KODI are using about the same amount of CPU and memory when browsing the KODI interface. I make sure to exit and reboot the android device between test.
Is there something I can test to provide further information? I posted at the NextPVR forum too, but was directed here.
I am going to try this version and see...
http://forum.kodi.tv/showthread.php?tid=...pid2489805
I tried the latest nightly of krypton for ARM v7.... kodi-20170102-ab7f182-Krypton-armeabi-v7a.apk
The NextPVR plugin is 2.4.10
The issue still occurs.
The playback is under the control of Kodi rather than the NextPVR addon, so not likely to be anything you can tweak in the NextPVR addon settings which will make any difference. That said, you could see if turning of timeshift in the NextPVR settings to see if it changes anything.
To me it sounds like some bug in Kodi 17 on your Android platform. Given it worked fine in older versions of Kodi, maybe try asking in the Android subforum (http://forum.kodi.tv/forumdisplay.php?fid=164). There is more likely to be developers there that can help you out with Android specific issues.
Thanks, actually when ahead and asked over there. It sounds as it might be media codec as for now it is still broken with Krypton (might be fixed by final release).
The thread over there for anyone else looking.
http://forum.kodi.tv/showthread.php?tid=...pid2491883
