Full Version: pvr.wmc stopped connecting - no longer see Live TV in menu
I have been using pvr.wmc successfully for over 2 weeks, so I know I had this setup correctly
- but today it seems to be unable to connect to ServerWMC.
I tried to reload and still unsuccessful.
- ServerWMC successfully starts
- and I can watch Live TV via WMC
- but no longer seeing 'Live TV' menu option in Kodi home screen
- Live TV is enabled and pvr.wmc is still installed and enabled
- only change I see it appears there was a windows update ran overnight, but don't see how that could have affected these apps
I do not see any logs for Kodi being generated...but so see ServerWMC logs (relevant logs below)
2017/01/06 08:08:52.348 New client connected: client: 'Kodi^HTPC-LR-PC2', IP: 127.0.0.1, machine: 'HTPC-LR-PC2', isRemote: False
2017/01/06 08:08:52.350 > path to Recorded TV Folder: 'C:\Users\Public\Recorded TV'
2017/01/06 08:08:52.355 AddonVersion> client: 'Kodi^HTPC-LR-PC2' has addon/plugin version: 0.6.9, OS: windows(6.1)
2017/01/06 08:08:52.373 Received client request: HTPC-LR-PC2|127.0.0.1|GetServerVersion|2017-01-06 15:08:52|127.0.0.1
2017/01/06 08:08:52.376 Finished request GetServerVersion in 0.00s
2017/01/06 08:08:52.470 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannels|True
2017/01/06 08:08:52.493 Finished request GetChannels in 0.02s
2017/01/06 08:08:52.511 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannelGroups|True
2017/01/06 08:08:52.517 Finished request GetChannelGroups in 0.01s
2017/01/06 08:08:52.524 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannelGroupMembers|True|Most Viewed
2017/01/06 08:08:52.527 Finished request GetChannelGroupMembers in 0.00s
2017/01/06 08:08:52.538 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannels|False
2017/01/06 08:08:52.551 GetChannels> DRM channel found: Drama/10.1 drm: PROT_COPY_INVALID
2017/01/06 08:08:52.572 Finished request GetChannels in 0.03s
2017/01/06 08:08:52.578 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannelGroups|False
2017/01/06 08:08:52.579 Finished request GetChannelGroups in 0.00s
2017/01/06 08:08:52.587 Received client request: HTPC-LR-PC2|127.0.0.1|GetChannelGroupMembers|False|Most Viewed
2017/01/06 08:08:52.587 Finished request GetChannelGroupMembers in 0.00s
2017/01/06 08:08:52.598 Received client request: HTPC-LR-PC2|127.0.0.1|ClientGoingDown
2017/01/06 08:08:52.599 ClientGoingDown> Client 'Kodi^HTPC-LR-PC2' disconnecting
2017/01/06 08:08:52.603 Finished request ClientGoingDown in 0.01s
2017/01/06 08:13:54.219 MainWindow::Window_Loaded> not running as service, checking folder status.
2017/01/06 08:13:54.219 MainWindow::Window_Loaded> Done
Any help/recommendations to troubleshoot this would be appreciated.
Thread moved to WMC section
@troberge please post the entire serverwmc log on pastebin.com. Also, are you running serverwmc as a service?
The kodi log is found in:
%appdata%\kodi
Thanks...
I just posted logs in pastebin.com.
ServerWMC.log: http://pastebin.com/qGSrLk52
kodi.log: http://pastebin.com/66f9mNr8
I am running with default settings and worked for about 2 weeks.
- So HTTP host service is not enabled
- my pvr add-on is set up to connect with default settings of using 127.0.0.1 on port 9080
Try deleting kodi's epg and tv database. You can do it from live tv settings menu, or delete them directly from here
%appdata%\kodi\userdata\database
then delete epg*.db and tv*.db. Best to do this with kodi not running. These databases will get refilled by serverwmc.
yup - that seem to work. But appears I have to re-add my logos, but its a small price to pay.
Thanks million - Big Grin
It depends on how you got your logos. If you get them serverwmc you should not have to do any reloading.
good point - i set up via kodi, maybe i will re-do this to WMC now. Thanks for the idea.
