Full Version: Context Menu
is its possible to go to a folder and in the context menu and choose set as watched - and it will change all files in there as watched?
i had a skin that had this but i cant remember which skin. Is there a skin that has it. or can i add it my self?
i have a lot of folders with files in there setting each file as watched is a Pain. Using a SQL database to keep track of it.
had a sql crash and the backup also got corrupted so i have to start over. But to put 7k files on watched manually is too much...
Use the context menu on the folder and set it as watched?
Tgx
there is no watched there. on the folder context menu.If there were i would not have asked it.
