The UPnp/DLNA client seems to be broken for Pictures. I have tried 2 servers, Plex and JRiver MC with the same results. The problem is at some random point it fails to navigate down into "subfolders" and just keeps presenting the same folder that you select so you can never get to the pictures. For example, I select my Plex server, then select Photos, My Photos Library, By Year, 2015. When I select 2015 it just keeps displaying the 2015 folder. It seems to happen randomly and not at the same folder level every time.
Note that this doesn't seem to happen in the Kodi DLNA client when browsing the same servers for videos (just pictures). Also note that I am able to browse pictures fine for these same servers with different DLNA clients other than Kodi.
I do have the same behaviour with Windows Server 2012 R2 as DLNA Server.
I agree fully that dlna does not function reliably in Krypton, while it was at least for my concerns fault-free under Jarvis.
I use dlna to stream pictures and videos from my android device to Kodi. The first two or three pictures are displayed by Krypton but then the streaming stops without any further response. I observed that it also occurs if the picture format and type changes and if I switch quite fast to the next picture.
Is there anybody else that is affected by the problem as well? May you please check it and response?!
I also encounter a problem using UPnP mode accessing a FritzBox. Indexation and creation of preview pictures seem to work but the actual picture cannot be displayed. A black screen is displayed but the picture never appears.
It works when accessing the box via SMB or FTP protocol.
It worked in version 16.
I could reproduce it on Android TV and a 'real' Android on my tablet, both are on 5.1.
... and just now I also reproduced on Windows 10 client.
Hello,
Same problem here with an Sony Bravia / Kodi 17 and a Synology NAS...
Tried on an iPhone with AcePlayer and everything is Ok...
Please fix that bug quickly because it's a feature I always use to show my work (photograph) at the office...
I will disable the automatic update in the future...
Thx.
Same here, although completely new with Kodi, started with 16.1, UPNP/DLNA connection with Synology NAS server was fine and reliable
upgrade to Krypton 17.1 and the same connection didn't work anymore.
I can connent via UPNP to my NAS, I can stream a video, but I can not get the subtitle streamed at the same time,
it's not the videoplayer in Krypton, becauses connected via NFS works fine.
Only disadvantage from NFS is that it is slower in connection with the NAS
I hope full UPNP/DLNA service will be updated very soon
Few months later, still have this problem...
Any solution ?
Thx.
Yes, sorry
untill now no solutions, UPNP still not working fine for me in Kodi 17.3
I switched to SMB because it's faster for me than FTP.
and SMB does support movei and subtitles to stream in one flow
There is nothing to fix. There is no DLNA client for pictures. There is no Pictures Library in Kodi. Pictures are only visible via Files view accessible from Kodi itself.
https://forum.kodi.tv/showthread.php?tid...pid2575700
@janvonflotow- Your questions are completely unrelated to this thread. This thread is about Pictures. You are talking about Videos and Subtitles. There are plenty of other threads regarding your question. Search for them.
Picture over UPnP worked before (I used it from July 2016 to March 2017).
Since Kodi 17, it is broken.
Interesting. What version of Kodi were you using? What is you operating system?
(2017-08-18, 00:46)Karellen Wrote: [ -> ]Interesting. What version of Kodi were you using? What is you operating system?
It's on Sony Bravia Android TV, Kodi 17.4.
So could you please add pictures support via upnp dlna in next releases, support for videos and music is stellar, why we forget pictures, i think it would add more complete experience to our media center, even windows dlna streams them via dlna and plex and emby
Thanks alot
(2017-10-24, 21:01)mohamedselim Wrote: [ -> ]So could you please add pictures support via upnp dlna in next releases, support for videos and music is stellar, why we forget pictures, i think it would add more complete experience to our media center, even windows dlna streams them via dlna and plex and emby
Thanks alot
Vote +1 for this missing feature. Pictures definitely should be accessible in DLNA configuration as Movies and Music libraries are.
Hi
This thread from 2017.
For me picture streaming with UPnp/DLNA not working. Is there a workaround to get pictures from Raspberry on Kodi?
