Full Version: Upgrading from Kodi 15 to Kodi 17
I'd like to upgrade to Kodi 17, but don't want to loose an my Aeon Nox background image configuration that I've already setup.
On Kodi15, there is a folder
C:\Users\Media\AppData\Roaming\Kodi\addons\skin.aeon.nox
which I've copied over as the \backgrounds folder has all my custom images.
However, I don't know where the configuration is stored.
Can anyone help?
thanks
This would seem to ask a similar question, and gets an answer http://forum.kodi.tv/showthread.php?tid=303770
Thanks - I had seen that thread but I don't have that path. It might be because I'm on an older version or have in-place upgraded historically.
I do have this folder for the library...
C:\Users\Media\AppData\Roaming\kodi\userdata
This contains SOURCES.XML and I also have a GUISETTINGS.XML which does seem to contain a lot of the Aeon Nox settings.
Copying this file over to another PC with a fresh Kodi v17 install seems to work, but it looks like it moves this config info out to somehwere else. i.e. a settings.xml here...
\AppData\Roaming\Kodi\userdata\addon_data\skin.aeon.nox.5
So it looks like Kodi has intelligent migration support!
