Full Version: Kodi in iOS 6?
Hello,
I have recently seen that now it is possible to install Kodi in iOS without jailbreak, using Cydia impactor. Does someone know if it is possible to install it on an iPad 4 with iOS 6? And if it is possible, which version of Kodi should I try?
Also, I have seen in the instructions that:
"This method also requires that Kodi be re-installed every 7 days if you are using a free iOS dev account."
Is this still like that? Isn't there any workaround to avoid this?
Thank you in advance for your help!
Cheers!
