Full Version: No information found for item
Hi!
I have 2 norwegian TV shows that kodi won't add.
This is the output from the log
Quote:23:24:57 T:140209157019392 WARNING: No information found for item '/TV/Valkyrien/', it won't be added to the library.
23:24:58 T:140209157019392 WARNING: No information found for item '/TV/Frikjent/', it won't be added to the library.
Both of these two shows exists on thetvdb.
I can't see any other errors telling me why the shows won't add.
I tried deleting the cache as described here without any luck...
How can I debug further?
Can you upload the full log to PasteBin or somewhere similar and supply their link here. Log line snippets like that are useless.
I turned on debug, heres the log output:
http://paste.ubuntu.com/23823641/
I suspect it's a language problem - you're using English as the scraper language, at a guess, when these shows will only show up if you use Norwegian or Finnish (for at least Valkyrien).
You can change the language of the scraper (say "no" if it offers to clean out your library!), re-scrape them, then change it back (again, declining the polite offer to obliterate everything). That should work, from memory. There may be other ways as well, e.g. a local NFO that points directly to the entry on thetvdb.com.
EDIT
Yes, the same is true for Frikjent - that only shows up in Norsk. Spot the difference between these two links:
https://thetvdb.com/?string=Frikjent&sea...ion=Search
https://thetvdb.com/index.php?function=S...&alllang=1
Or add the English info to thetvdb.
Both shows are on themoviedb.org, but episode summaries are not in English
