Full Version: Try to made AEON White
Hello,
i trie to made the skin more white but I stuck on the seekbar
How do I change the bottom bar?
thx for help.
The bottom bar is located here: https://github.com/BigNoid/Aeon-Nox/blob...tombar.png
The code is in DialogSeekBar.xml
ok. it was midtexturebg hmmm..
is it possible to change the font color under the seeker from "theme color" to "white" only where the seekbar is?
What do you think?
a small tweak. Tell me what you think. I like it.
Hi can you post your changes thanks
it is only a bit that I managed to do. but feel free.
download
Thank you very much it works wonderfully
thank you
