############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Apr 20 21:36:07 SAST 2017
Kodi Options:
Arch: x86_64
Kernel: Linux 3.13.0-116-generic #163-Ubuntu SMP Fri Mar 31 14:13:22 UTC 2017
Release: Ubuntu 14.04.5 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/chetan/core (2017-04-20 21:36:07.839891020 +0200)
[New LWP 2662]
[New LWP 2666]
[New LWP 2664]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/x86_64-linux-gnu/kodi/kodi.bin'.
Program terminated with signal SIGABRT, Aborted.
#0 0x00007f50a8acfc37 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
Thread 3 (Thread 0x7f5094ffa700 (LWP 2664)):
#0 pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:143
#1 0x0000000001298199 in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#2 0x0000000000c3e823 in CThread::Action() ()
#3 0x0000000000c3ef91 in CThread::staticThread(void*) ()
#4 0x00007f50afbbf184 in start_thread (arg=0x7f5094ffa700) at pthread_create.c:312
#5 0x00007f50a8b96bed in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 2 (Thread 0x7f508bffe700 (LWP 2666)):
#0 0x00007f50a8b8984d in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x0000000000973230 in CFDEventMonitor::Process() ()
#4 0x00007f50afbbf184 in start_thread (arg=0x7f508bffe700) at pthread_create.c:312
Thread 1 (Thread 0x7f50aff93840 (LWP 2662)):
#1 0x00007f50a8ad3028 in __GI_abort () at abort.c:89
#2 0x00007f50a90d7535 in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007f50a90d56d6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007f50a90d5703 in std::terminate() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5 0x00007f50a90d5922 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x0000000000e1c9d4 in dbiplus::SqliteDataset::query(std::string const&) ()
#7 0x0000000000e08289 in CDatabase::GetDBVersion() ()
#8 0x0000000000f0a941 in CDatabaseManager::Initialize(bool) ()
#9 0x0000000000edc838 in CApplication::Create() ()
#10 0x0000000000c6ff07 in XBMC_Run ()
#11 0x00000000007e1f4b in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
21:36:07.131 T:139984526456896 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:36:07.131 T:139984526456896 NOTICE: -----------------------------------------------------------------------
21:36:07.131 T:139984526456896 NOTICE: Starting Kodi (17.1 Git:20170320-nogitfound). Platform: Linux x86 64-bit
21:36:07.131 T:139984526456896 NOTICE: Using Release Kodi x64 build
21:36:07.131 T:139984526456896 NOTICE: Kodi compiled Mar 20 2017 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
21:36:07.131 T:139984526456896 NOTICE: Running on Ubuntu 14.04.5 LTS, kernel: Linux x86 64-bit version 3.13.0-116-generic
21:36:07.131 T:139984526456896 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
21:36:07.131 T:139984526456896 NOTICE: Host CPU: AMD Turion(tm) II Neo N40L Dual-Core Processor, 2 cores available
21:36:07.131 T:139984526456896 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:36:07.132 T:139984526456896 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi
21:36:07.132 T:139984526456896 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi/addons
21:36:07.132 T:139984526456896 NOTICE: special://masterprofile/ is mapped to: /home/chetan/.kodi/userdata
21:36:07.132 T:139984526456896 NOTICE: special://envhome/ is mapped to: /home/chetan
21:36:07.132 T:139984526456896 NOTICE: special://home/ is mapped to: /home/chetan/.kodi
21:36:07.132 T:139984526456896 NOTICE: special://temp/ is mapped to: /home/chetan/.kodi/temp
21:36:07.132 T:139984526456896 NOTICE: special://logpath/ is mapped to: /home/chetan/.kodi/temp
21:36:07.132 T:139984526456896 NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi.bin
21:36:07.132 T:139984526456896 NOTICE: Local hostname: chets-cloud
21:36:07.132 T:139984526456896 NOTICE: Log File is located: /home/chetan/.kodi/temp//kodi.log
21:36:07.132 T:139984526456896 NOTICE: -----------------------------------------------------------------------
21:36:07.231 T:139984526456896 NOTICE: load settings...
21:36:07.271 T:139984526456896 ERROR: PulseAudio: Failed to connect context
21:36:07.271 T:139984526456896 NOTICE: PulseAudio might not be running. Context was not created.
21:36:07.384 T:139984526456896 NOTICE: Found 1 Lists of Devices
21:36:07.384 T:139984526456896 NOTICE: Enumerated ALSA devices:
21:36:07.384 T:139984526456896 NOTICE: Device 1
21:36:07.384 T:139984526456896 NOTICE: m_deviceName : @
21:36:07.384 T:139984526456896 NOTICE: m_displayName : Default (HDA NVidia HDMI 0)
21:36:07.384 T:139984526456896 NOTICE: m_displayNameExtra:
21:36:07.384 T:139984526456896 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:36:07.384 T:139984526456896 NOTICE: m_channels : FL,FR
21:36:07.384 T:139984526456896 NOTICE: m_sampleRates : 32000,44100,48000
21:36:07.384 T:139984526456896 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:36:07.384 T:139984526456896 NOTICE: m_streamTypes : No passthrough capabilities
21:36:07.384 T:139984526456896 NOTICE: Device 2
21:36:07.385 T:139984526456896 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=0
21:36:07.385 T:139984526456896 NOTICE: m_displayName : HDA NVidia
21:36:07.385 T:139984526456896 NOTICE: m_displayNameExtra: HDMI #0
21:36:07.385 T:139984526456896 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:36:07.385 T:139984526456896 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
21:36:07.385 T:139984526456896 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
21:36:07.385 T:139984526456896 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
21:36:07.385 T:139984526456896 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,S
TREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
21:36:07.385 T:139984526456896 NOTICE: Device 3
21:36:07.385 T:139984526456896 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=1
21:36:07.385 T:139984526456896 NOTICE: m_displayNameExtra: HDMI #1
21:36:07.385 T:139984526456896 NOTICE: Device 4
21:36:07.385 T:139984526456896 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=2
21:36:07.385 T:139984526456896 NOTICE: m_displayNameExtra: HDMI #2
21:36:07.385 T:139984526456896 NOTICE: Device 5
21:36:07.385 T:139984526456896 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=3
21:36:07.385 T:139984526456896 NOTICE: m_displayNameExtra: SNY SONY TV on HDMI #3
21:36:07.385 T:139984526456896 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
21:36:07.395 T:139984526456896 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:36:07.395 T:139984526456896 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
21:36:07.396 T:139984526456896 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
21:36:07.396 T:139984526456896 NOTICE: Default Video Player: VideoPlayer
21:36:07.396 T:139984526456896 NOTICE: Default Audio Player: paplayer
21:36:07.396 T:139984526456896 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:36:07.396 T:139984526456896 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:36:07.397 T:139984526456896 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
21:36:07.397 T:139984526456896 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:36:07.398 T:139984526456896 NOTICE: Loaded playercorefactory configuration
21:36:07.398 T:139984526456896 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:36:07.398 T:139984526456896 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:36:07.408 T:139984526456896 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT idVersion FROM version
############### END LOG FILE ################
