Hi
I followed the install steps to install kodi
no errors, after install no KODI icon appears
I used ifile, downloaded ios version *.deb and choose install
I started Cydia and it shows Kodi 17 installed ==> no icon shows
any hints ?
thx
mike
of course I tried this
this is standard procedure
2)
meanwhile also tried on ipad-mini, same effect
no kodi icon
kodi doesnot start
Having same issue on IOS 9.0.2 IPAD4 and Jailbroken. Downloaded deb file, and Kodi won't even open. Had to downgrade back to 16.1. Hope I can get Krypton 17 via deb file from Kodi officially. Thanks
Hi I have the exact same issue and I installed RC4 and installed beta7
Tried a respring and also a full reboot, and the icon still does not appear.
Is it worth trying an earlier beta?
I'm using an iPhone 5, iOs 9.2.1, Home Depot Jailbreak
EDIT:
After another reboot and re-enable the Jailbreak with Home Depot the icon appeared!
This is with beta7, I'll try RC3 in a bit.
EDIT 2:
Kodi RC3 works fine also, Kodi icon appears after reboot and respring after Home Depot.
Fingers crossed you'll get this fixed in RC5
On an iPhone 7 Plus with iOS 10.1.1 and jailbreak, it works me correctly, but on an iPad Air 2 with iOS 10.2 and not jailbreak. It is normal?
SSH into the iPad root and your password default is alpine, at the prompt type uicache the icon will appear
For Kodi 17 and iOS 10.2
Fix Kodi crash problem
open Mterminal , type su
type root password (default password alpine)
copy following each link and press enter each time
cd /Applications/Kodi.app
find $PWD/ -name *.so -exec ldid -S {} \;
find $PWD/ -name *.dylib -exec ldid -S {} \;
