Full Version: Does Emby (or Plex) work good w/ PseudoTV Live?
Is Emby supported?
I will admit when switching between my content in Kodi, it takes 3-5 seconds before the show/movie will actually start.
But when inside PTVL, and I'm trying to change channels, it'll take 5-10 seconds to change the channel - annoying and I'm ready to give up. First of all, I plan on following up with Emby to figure out if 3-5 is the norm, secondly, does any1 else use emby and PTVL and have better luck? Or any1 use Plex for that matter?
I seen the demos and it works smooth w/ 1 second channel changes - Do those demos have their media on the same maching?
For those that are interested - yes it does work and good after initial setup. DO NOT USE PLUGIN method, I switched to direct paths, which are now smb vs plugin:// and my channel changing is 10x better! I think I can actually use it now after making this switch. I just played with it for a few minutes, but can already tell the difference. I will get more involved with it later
