Full Version: Remove space between icons
Thanks for Amber, it's a fine skin.
Is it possible to remove or reduce the spacing between posters in the Icons video View Mode?
UPDATE: I'm ok with editing XML if that helps, I could just use a pointer or two on which files to edit and what attributes to tweak.
