Full Version: new keyboard combination to implement when using Kodi v17 or above
since v17, kodi uses a different keyboard combination for display stats:
till v16.1: press "o" on keyboard or hold "i" in iOS "Kodi Remote App" to get it shown
since v17: press CTRL + Shift + o on keyboard
Can you please make the app to use the new combination when using v17 or later to get display stats also on v17 or above?
Add a custom button on the remote control view right side for "Player Process info" window in the meantime.
Where is Player Process info? There are so many categories.
EDIT: Found it, but codecinfo and playerprocessinfo do the same.
I use Confluence if that has to do with it?
EDIT 2: I found it. It's called "playerdebug"
nice catch, me neither knew about the playerdebug action Smile I will map then the action "playerdebug" to the long press "i" for kodi v17 and higher
