2017-02-11, 18:31
Created custom colors for the default Kodi skin Estuary and I thought I would share them with you guys and gals.
Here is some screenshots of the colors with the transparency effect (more screenshots further in the thread).
UPDATE
With the extra colors, all the original Estuary's colors is now included with added transparency effect, link below.
UPDATE
All the mods from this thread + pkscout's mods, except for Artist Slideshow support, are included in this Estuary Mod addon below for a easier installation.
Pkscout's mods added:
- option to trigger music visualization screen when you start playing music
- ability to reorder and turn off home screen left menu items
- option to use small icons for the categories (makes it more like the original Estuary)
- option to hide home screen widgets individually
- added categories in TV category widget for X-NEWA and Pseudolibrary if those addons are installed
Link: skin.estuary.krypton.vitorp07.mod v.1.1 - added colors
If you want or need Artist Slideshow support install pkscout's mod instead, here is the link to his thread.
Thanks goes to pkscout for his mods, I will delete the addon if he is not ok with me using his mods in this addon.
EDIT
Here is how to install the colors mods and/or the transparency effect mods from this thread without installing the addon above.
*Before you proceed, you will probably need to change "permissions" of the skin.estuary folder to be able to make any changes to it.
Download and extract these zips: colors.zip & xml.zip *links will be updated whenever new mods are applied
- Replace Estuary's "colors" folder with the colors folder extracted from colors.zip
- Without deleting the folder, overwrite/replace the files within the Estuary's "xml" folder with the included files extracted from xml.zip
UPDATE
UPDATE
EDIT
