set unwatched as a default view, instead of having to select it every time the app is opened. Support for smart playlists. Thanks
for the first question, I will check the feasibility. For the second question you mean the video smarlist? because music smart playlists are already there
Sorry, should have been more specific. Yes, video playlists.
So, I have checked the feasibility and it's harder than I thought for the mix nature of this kind of playlist that can be composed with movies or tv shows or music videos, and it's impossible to know in advance in which kind of video the playlist belongs to.
So, if I will able to sort this out, this will require more time than expected.
