I'm looking for the NRJ radio add-on and I can't find it.
I was following this:
http://kodi.wiki/view/Add-on:NRJ_Radio
But when I go to
"Kodi add-on repository > Music Add-ons" I cannot find
NRJ Radio
Am I missing something?
That add-on (along with 19 others from the same developer) was removed from the kodi repository a few days ago.
You can still find it though through github's "history".
You'll have to download the whole version of xbmc/repo-plugins, one version before the removal commit. Here:
https://github.com/xbmc/repo-plugins/tre...09f37a1412 (Clone or download/Download zip)
Then you'll have to extract
plugin.audio.nrjradio from that .zip, put it in another .zip and install it on kodi.
But first you have to install a dependency that no longer exists where the add-on expects it to be (the author's personal github page -that was also deleted), but I uploaded it on my github,
here it is.
Very uncomfortable if you're not familiar with this stuff, but currently I'm not aware of any other way.
Also, I guess you should consider it unsupported here.
if you want only listen the radio you can use a radio addon instead of the NRJ_radio addon.
i think you can find a good stream in "tune.in" or "rad.io" addon. also a simple link over internet inside a .m3u file will do the trick.
Peppe
(2017-02-15, 00:16)host505 Wrote: [ -> ]That add-on (along with 19 others from the same developer) was removed from the kodi repository a few days ago.
Then you'll have to extract plugin.audio.nrjradio from that .zip, put it in another .zip and install it on kodi.
But first you have to install a dependency that no longer exists where the add-on expects it to be (the author's personal github page -that was also deleted), but I uploaded it on my github, here it is.
Thank you! I was looking for this this addon for the past few days and got so frustrated.
I installed the nrj add-on and it works great! Thank you for saving these add-ons.
I'm just curious why did they decide to remove these add-ons?
Long story... But it doesn't have anything to do with his add-ons on the kodi repo (afaik).
