I changed my skin to Estouchy on a Nvidia box and now I can't change baxk to a regular skin since I need a touch screen to do so. I do not have a touch screen device. Any way to change the skin back. I can not access settings since I don't have a touch screen device. Thanks for your help
Hook up a mouse as that's the easiest way.
how did you manage to change the skin to estouchy without a mouse or touchscreen?
it shouldn't be possible...
please let me know so we can prevent others from making the same mistake.
Thank you both very much for the responses!
I was able to change it because I use a Nvidia box and that is how I access Kodi. I have a remote control with it. Once I changed it to Estouchy I could no longer use the remote to get to settings. I can still navigate through the system with it but cant type in anything in search or access settings again. I will try the mouse through the box and hopefully that helps resolve the issue.
Thanks again!
