Full Version: CU LRC Lyrics extended
ronie
Earlier, I asked for support to implement the expanded format of the lyrics. You replied that it was unclaimed.
I did it myself for yourself in your plugin.
Can I share a modernized version of your plugin with the preservation your copyright?
With the approval of "ronie", a fork of the project opened via the link: https://github.com/IgorA100/script.cu.lrclyrics.ext
Current version: https://github.com/IgorA100/script.cu.lr....3.7-2.zip
(2017-02-21, 15:33)IgorA100 Wrote: [ -> ]ronie
sure, of course.
all you need to do is change the addon name and the addon id, so it doesn't conflict with my version.
i don't care about credits, so please add your name in the provider-name field in addon.xml ;-)
(2017-02-21, 16:01)ronie Wrote: [ -> ]sure, of course.
O, Yes!
Many thanks!
Yes, of course, I changed the name of the plugin to "script.cu.lrclyrics.ext" that there were no conflicts with your plugin.
It looks like a modified plug-in:
http://savepic.ru/13010255.png
(2017-02-21, 16:15)IgorA100 Wrote: [ -> ]
O, Yes!
Many thanks!
Please, share with us mate Wink
sagrath
No problem Smile
The code is still in the process of debugging is unnecessary comments.
My revision searches for tags Enhanced LRC format. If there are such tags, switched my processing algorithm.
https://en.wikipedia.org/wiki/LRC_%28fil...ced_format
[mm:ss.xx] <mm:ss.xx> line 1 word 1 <mm:ss.xx> line 1 word 2 <mm:ss.xx> ... line 1 last word <mm:ss.xx>
Plugin:
https://drive.google.com/file/d/0BxSw65h...EwtSFVqdkk
Update to 5.3.7-1
https://github.com/IgorA100/script.cu.lr....3.7-1.zip
(2017-02-21, 18:55)IgorA100 Wrote: [ -> ]sagrath
No problem Smile
Plugin:
Update to 5.3.7-1
That's so cool!!!
But, how we can make these? There some program to help, or we need to made this with our brave and courage? I mean, typing?
Help, I have not posted.
I think there is nothing complicated to install the plugin.
Install the plug-in ZIP file. In the setting of all similarly in origianlnom plugin from "Taxigps" & "ronie".
Enter only one extra configuration "The number of lines before and after the current". The default is 3 lines
The plugin itself identifies existence of Enhanced LRC format file.
New: https://github.com/IgorA100/script.cu.lr....3.7-2.zip
