I recently upgraded from Kodi 15 to Kodi 17, and reinstalled Confluence immediately after updating. I noticed a minor issue, and not 100% sure if it is a skin problem or not. In Kodi 15, when I paused a video, it would show "PAUSED" up in the right hand corner. In Kodi 17, now it shows "SEEKING", which I previously only saw when I was skipping backwards/forwards. my OCD is going crazy seeing the wrong thing
feedback would be appreciated, thanks.
You could try and update Confluence skin from the github repo and see if that solves your issue.
I never saw this issue from Kodi 15.x to 18.x with Confluence skin.
My most educated guess would be an old version of Confluence skin.
If all fails you could try the new default skin and see if it contains the same issue or not (probably not).
i have the same issue. skin showing seeking instead of paused. reinstalled skin but still the same. any fix pls?
Not that +1s are terribly useful, but...
+1
I have the same problem. Running 17.1 using Confluence; when pausing a video it shows "SEEKING" instead of "PAUSED" in the upper right corner.
(2017-02-23, 06:36)gitman Wrote: [ -> ]I recently upgraded from Kodi 15 to Kodi 17, and reinstalled Confluence immediately after updating. I noticed a minor issue, and not 100% sure if it is a skin problem or not. In Kodi 15, when I paused a video, it would show "PAUSED" up in the right hand corner. In Kodi 17, now it shows "SEEKING", which I previously only saw when I was skipping backwards/forwards. my OCD is going crazy seeing the wrong thing feedback would be appreciated, thanks.
see if changing the skin resolves your issue. in my case, seeking is like buffering when i skip the movie forward or backward
this issue is still present. any fix pls?
Sent from my SM-G920F
I also have the same issue in Kodi 17. I know its not a big issue but would love it if it could be fixed
Temp fix for confluence-3.0.39-[Kodi 17]; Get "PAUSED" instead of "SEEKING" when pausing video:
Change 31046 to 31043 in line #112 in file addons/skin.confluence/720p/Includes.xml
Hey Gamli did u find out I have the same problem here pausing but it seeking
Does any one know how to fix that
How do I fix when u pause the movie it seeking!!!!
Help I have kodi17.1 krypton
