When I first open Kodi on Windows 10, it connects to the Plex Media Server and lists the Movies and TV Shows sections on the Home Screen, however the shelf for both the Movies or TV Shows does not populate, as in it does not display the On Deck, or Recently Added movies. If I go into the Movies section to view the listing of movies and then back out to the Home Screen, the Shelves are populated. Please see screenshots below.
Using the most updated versions of everything: Windows 10, Kodi v17.0, PleXBMC 4.1.0, Amber v3.0.6
This is most likely because Plexbmc has not started before the home window starts therefore it has no content to display, if plexbmc could provide a way of telling if it is running we could delay startup until after that, the same can be done with skin widgets.
Thanks for the prompt reply. However, if PleXBMC has not started it does not even display the Movies or TV Shows or Channels sections on the Home Screen. Those sections are only displayed after PleXBMC starts and makes a connection to the Plex Media Server. If the Plex Media Server is off for example, then those sections are not even listed and PleXBMC reports it is unable to find any servers.
On top of that, even if I wait 1 minute for PleXBMC to start up fully, then go to Settings and hit "Refresh" or "Reload Skin", the shelves still do not populate.
Another weird behaviour, is if I go into the Movies section, then back out, it populates the shelf for Movies, but the shelf for TV Shows is still empty.
If I then go into the TV Shows section, then back out, it populates the shelf for TV Shows, but the shelf for Movies which was populated is now again empty. Just from this behaviour of only 1 shelf being populated (either Movies or TV Shows), and not both at the same time makes me think it is not an issue with PleXBMC not starting before the Home Screen.
This may be specific to Windows 10. I do not have this issue with Kodi v16.1 and Amber skin on my Fire TV box.
i have a similar issue with my installations.
Same behaviour as described below on every machine that runs Kodi 17.0 and amber (3.05 and 3.06)
No Problems on every machine with Kodi 16.1 and amber (3.05).
I tried a clean installation of 17.0 and an upgrade from 16.1. Same result...
No Config-Changes are made in Plex-Server.
Server (Plex 1.3.4.3285) is running on Synology DS514play (DSM 6.0.2-8451 Update 9)
My installations:
1. FireTV-Box (all Updates)
2. FireTV-Stick (all Updates)
3. Win10-PC (all Updates)
Issue:
The connection to the plex server is etablished and my Plex-Libraries are displayed in the skin (as in 16.1)
But nothing happens, if i want to open a library, No content (movies, TV-Shows, etc.) is displayed (but i can hear the click-sound).
If i switch from Plex-Mode to Kodi-Mode, i can browse and play the movies without any problems via "movies->video-addons-> PlexBMX"
So from my point of view not Win10-specific...
Any ideas?
Best regards.
OK, I've installed plex to try and fix this so I'll see what I can do (had to delete my plexbmc addon data for it to even connect though)
I tired it only in W10. No effect, issue still there.
Another hint: I enabled the "recently added"- view in the main menu (in 3.06 and in branch)
If i scroll (arrow up/down) to the library-entries, he recently added movies are displayed and can be started.
If i click (Mouse or Enter-Button) to go into the libraries, nothing happens....
(2017-02-24, 16:44)stroti Wrote: [ -> ]I tired it only in W10. No effect, issue still there.
Hi
Can you delete the addon_data for plexbmc and restart form here:
C:\Users\<username>\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.plexbmc
I deleted the folder plugin.video.plexbmc.
Restart of the pc
Starting Kodi
(It swiched automatically to Kodi-Mode and i switched back to plex)
Same issue still there...
I uninstalled Kodi. Restarted my computer. Installed Kodi. Then installed the new Plexbmc add-on by Tgxcorporation which you have linked in the forums.
Then I installed the Amber skin from the official repo, and the issue persisted. So I then uninstalled the skin, and I downloaded the fix you posted today in this thread. And BAM, it works!
What was the issue?
Thanks for the fix! And the quick turnaround.
(2017-02-25, 04:41)theuser86 Wrote: [ -> ]I uninstalled Kodi. Restarted my computer. Installed Kodi. Then installed the new Plexbmc add-on by Tgxcorporation which you have linked in the forums.
What was the issue?
There was a fault with some of the visibility conditions which used the Kodi IsUpdating boolean, this doesn't work with Plex so I had to put in a flag to skip this evaluation when in plex mode.
Interesting - will the fix you created but pulled into the official Amber skin?
now i tried the same on my FireTV-Device an it is working!
After this, i recognized, that Kodi 17 and FireTV are not supporting DTS an therefore i had tot go back to 16.1.
Grrrrh.
Best regards!
(2017-02-27, 02:59)theuser86 Wrote: [ -> ]Interesting - will the fix you created but pulled into the official Amber skin?
It has been accepted by jester and should be in 3.0.7 (probably in a couple of weeks)
