Hi.
Im using a Intel NUC with SSD.
I have just installed Ubuntu 16, and installed kodi.
I have a problem that Kodi boots faster than the network is ready, or at least i think that is the problem.
I can add network sources after kodi has started, but at next reboot i can't access them. It's SMB shares.
I can't see the shared mysql database either, i have en empty library.
I start kodi with lightdm.conf as i have read here:
http://kodi.wiki/view/HOW-TO:Autostart_Kodi_for_Linux
Solution 1+6
How do i delay the boot, or get it to wait for the network to be ready before starting kodi?
This NUC is the "updater" for our system here at home, so i would like to get it working ASAP
How should the lightdm.conf look if i need to add the code wsnipex wrote?
Like this?
start on ((filesystem
and runlevel [!06]
and started dbus
- and plymouth-ready)
+ and plymouth-ready
+ and (starting network-interface
+ or starting network-manager
+ or starting networking)
or runlevel PREVLEVEL=S)
stop on runlevel [016]
[Seat:*]
#autologin-guest=false
#autologin-user=kodi
#autologin-user-timeout=0
autologin-user=kodi
autologin-session=kodi
You obviously don't add the "+" and "-" signs.
Post your lightdm.conf when you are ready.
Depending on the OS you are using - there is a better method with systemd ...
edit /lib/systemd/system/lightdm.service
and in the second line where it states:
Quote:After=systemd-user-sessions.service [email protected] plymouth-quit.service
Change it to:
Quote:After=sound.target network-online.target systemd-user-sessions.service [email protected] plymouth-quit.service
Now do:
sudo systemctl disable lightdm
sudo systemctl enable lightdm
sudo reboot
Done.
Now when it boots it has stopped before gui, and there is this on the screen:
/dev/sda1: clean, 240432/7299072 files, 1684462/29190656 blocks
If i push the power button, it shuts down correctly, but it's the same when i turn it on again
I can also connect to it via putty.
rather sounds like you did not enable lightdm anymore.
Undo the changes and try again ..
By undo, you mean change
to
again right?
Did that, and
sudo reboot
afterwards, same result as before -
(2017-02-25, 18:37)fritsch Wrote: [ -> ]Remember: v16 is outdated and not suitable for a nuc.
What OS should i be using on my NUC if not Ubuntu 16.04?
Then you broke something totally and absolutely NOT related to the above changes ...
post:
systemd-analyze critical-chain
and:
systemctl status lightdm
All in a pastebin
(2017-02-25, 22:09)Dennisreneholm Wrote: [ -> ] (2017-02-25, 18:37)fritsch Wrote: [ -> ]Remember: v16 is outdated and not suitable for a nuc.
Kodi version 16 is outdated.
sudo systemctl restart lightdm ...
lightdm seems dead :-) - sure that you did not edit something in a wrong way?
