Full Version: kodi 17 crash on startup
Hello world !
Sometimes when I start Kodi, it's crash. In the beginning I supposed that's was a video accelerator problem (vaapi with a intel HD2000 desktop pc and a intel GMA 4500HDnotebook, all on mint 18.1). I tried to fix the problem by disabling hardware acceleration in kodi. But today my desktop with an AMD graphics card crashed too (mint 18.1 too) and my others pc crashed again. When I start kodi via command line, it's run goodand return nothing.
I post you the log via pastebin http://pastebin.com/BLmvzXQD from my AMD graphics card desktop.
install the kodi-inputstream.adaptive plugin or configure the youtube addon to use internal dash
Is the problem the same on my intel desktop computer ?
I launched kodi 2 times this morning. The first one was good, and the second returns me a message in command line :
Segmentation fault (core dumped)
find: «/home/test/.cache/dconf»: Permission denied
I post the pastebin http://pastebin.com/9y7UpDNy
and when I'm launching kodi in command line when I'm enabling VAAPI it's return :
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_39
libva info: va_openDriver() returns 0
libEGL warning: bad surface attribute 0x3081
WARNING: Invalid RefPicListX[] entry!!! It is not included in DPB
doesn't looks like the same issue, but you didn't enable Debug Log
I post you the kodi.log :
http://pastebin.com/qpsjAwbj
and the crash.log :
http://pastebin.com/U59RYXNK
Please note here, the hardware acceleration (VAAPI) is enabled
that crash is somehow related to pvr.
You could try to disable/uninstall the hts addon and upgrade to v17.1rc1 from the unstable ppa
Thanks for your answer. Do you want me to test if the rc1 works fine for me ? I can wait the stable 17.1 to work with it, the crash doesn't stop my usage of kodi.
