Full Version: TV channel restarts after 2-3 seconds
So I decided to try out 17 and 17.1 rc but both gave me the same result,
Problem:
when I go and select a Channel the PVR. it starts playing but after 2-3 seconds it goes back to the initial start of the video (as in where it first started when I clicked the channel) and then it plays fine until i change the channel, then it does the same 2-3 second rewind at start of TV stream.
anyone else experience this issue?
I've tested this on both Android 6.0 and on LibreELEC 8
So I was able to upload a LOG of the issue wiht the channels restarting after you select one.
Hope someone can look into this?
https://pastebin.com/vinufN9d
someone let me know what else i can upload so someone can fix this
