2017-03-04, 03:27
Hello,
Not sure if this is a problem with Kodi or just me not reading MediaInfo right, would appreciate someone's help please
Setup details:
Kodi - 17.0
PC - Lenovo T510 (nVidia NVS3100m)
OS - Windows 10 64-bit
AVR - Onkyo TX-NR717
Connectivity - Laptop (DisplayPort to HDMI converter) -> AVR -> TV
The NVS 3100m doesn't have hardware support for HD formats however it does support 8 channel output. Therefore I have set Kodi's audio settings to WASAPI and enabled passthrough only for the lossy audio formats (DTS-HD and Dolby TrueHD disabled).
Problem:
I can get TrueHD audio decoded in Kodi and come to my AVR as LPCM (I can hear the beautiful quality immediately) but DTS-HD movies are not decoded and instead are bitstreamed as DTS (AVR says "DTS").
This is what MediaInfo is saying about one particular movie I have however I can't tell if it's HD or not as even MediaInfo seem unsure??
Setup details:
Kodi - 17.0
Problem:
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1 h 47 min
Bit rate mode : Variable / Constant
Bit rate : Unknown / 1 509 kb/s
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
