Full Version: KODI 17.0 Mac OS Sierra error
Hello
Since I updated KODI to 17.0 I can't boot KODI, it keeps giving me the error 'kodi stopped unexpectedly'.
I'm on a macbook with OS Sierra.
This is my log http://pastebin.com/Hv4PNiDD
Can someone please help me?
Thanks in advance!
13:49:35.240 T:140736881288128 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT idVersion FROM version
Your database is corrupt, you need to delete it and let kodi rebuild it.
delete addons27.db from your userdata (wiki) (databases) folder
that worked! Thanks a lot!!
(2017-03-04, 15:12)jensness Wrote: [ -> ]that worked! Thanks a lot!!
Hit the thank user button Smile i am collecting points for being good Smile
He doesn't have enough posts yet for that button to be enabled.
Hi same issue as above here's my log:
http://pastebin.com/crRvBKAt
Thanks...
Link doesn't work
sorry to ask this but how can I get to
/private/var/mobile/Library/Preferences/Kodi/userdata/
to delete the corrupt DB if Kodi never opens?
thanks
(2017-03-22, 22:59)matthos Wrote: [ -> ]sorry to ask this but how can I get to
thanks
in Finder point to "go" and hold the "option key" library will appear
I clicked go+option and navigated to Library/Preferences/ but there is no Kodi folder, what am I missing (there is no /private folder under Library)?
thanks
(2017-03-22, 23:37)matthos Wrote: [ -> ]I clicked go+option and navigated to Library/Preferences/ but there is no Kodi folder, what am I missing (there is no /private folder under Library)?
thanks
go+option, library ->>> the kodi folder is in the "application support" subfolder !
How do I go about deleting the addons27.db? Do I open it in text edit and delete every line that has that in it?
Move the file to the trash
Solved in my post
