Full Version: Error installing Rapier out of DEV Repo
Another Bug if you install and activate Rapier out of your Dev Repo from the Addon Manager: The Homescreen will not be loaded.
https://youtu.be/K84-DjZG9hM
However i think this is a Kodi internal Problem maybe.
Kodi log says:
19:11:21.255 T:8404 WARNING: CSkinInfo: failed to load skin settings
So maybe there is no default settings.xml?
// sorry for flooding Smile
Hi skybird.
I experienced the same thing recently on my Rpi2.
Try to install some other skins from the official repo (and switch directly to them after install) and let me know if the same thing happens.
I also think this is a Kodi issue.
Ok, i tested now a few addons from kodi repository.
App TV ist not working, Amber is.
I thinks that would be really a kodi issue. i try to add this to tract.
Edit: http://trac.kodi.tv/ticket/17382#ticket
Thanks a lot for following up on this.
If it's a skin problem (although I'm pretty confident it's not), I'll be happy to fix it.
We'll see what the trac ticket leads to.
When I have some more time, I'll investigate this too.
