2017-03-07, 09:21
2017-03-07, 09:23
Sorry, solved.
My error.
My error.
2017-06-01, 17:54
(2017-03-07, 09:23)mamachan Wrote: [ -> ]Sorry, solved.
My error.
How??
I know this old, but it would be nice if you could tell others how you fixed this.
2017-06-03, 04:20
@Nalco
You need some help with that, its not hard if you spend some time reading the wiki, i like making my own nfo files, okay like is a BIG word after 249 Movies the fun has gone where the Sun never shines , but
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<movie>
<title>A Sound of Thunder</title>
<id>tt0318081</id>
</movie>
Save that with an xml or nfo ext depending on you media you could also have done this
<movie>
</movie>
www.imdb.com/title/tt0318081/
save file as video.xml put it in the root folder
so that would be
Movies\A Sound of Thunder <----- In that one video.xml
it will then get artwork and plot simple but takes time to make, them your self but fun
If you at some point feel the need to hit the PC take a break from finding all the imdb codes
<movie>
<id>tt0318081</id>
</movie>
<movie>
</movie>
so that would be
