Hello everyone,
I think Titan recently updated. The update added sub menus to my main menu I figured out how to change that back. Now I noticed that my movie sets used to show on the bottom right corner how many of the movies within the set were watched, now it's gone it was like a disc showing 1/3 movies not watched it's gone how can I get that back? Also, the disc art used to randomly select a disc art from within the movie sets now it doesn't. Can someone please help me out?
I'm also not getting any info on the movie sets collection title. When I click to go to the movie collection I get info what happened?
Just noticed my backgrounds don't change with the movies either. :/
By the way I'm using Kodi 16.1 Jarvis with the latest titan skin on PC
I'm going to update to krypton hope that fixes the problem.
Alright I did a clean install and still the same I think it's just how titan is designed now. Can somebody help me out? Is this just the way it is now?
I think I found out why. It's because of the skin helper service update.
Wow, you do seem to have a lot of patience. Remember this is opensource, free software and it can take some days before someone replies to your questions.
For that same reason; the skin broke due to a dependency which was upgraded before the skin did.
A new skin update is already pending to be submitted on the repo so your issue should be fixed within a couple of days.
If you can't wait, I'd suggest you to temporary switch to the beta version of the skin. See the main thread, first post for details.
I just wanted to make sure that if anyone else reads this they would see what I did I know it takes a while to get a reply. That's why I was trying to figure it out on my own. That's when I found the thread saying it is the skin helper service. Thank you for the reply.
(2017-03-11, 20:49)marcelveldt Wrote: [ -> ]OK, fair enough.
If you want to temporary downgrade to the previous skinhelper version untill the skin is updated on the repo, here's a manual link:
http://mirrors.kodi.tv/addons/jarvis/scr....0.100.zip
Thank you i will try to downgrade tonight. I appreciate it.
Hey marcelveldt,
I recently updated to the new titan skin so also updated the skin helper. Everything seemed to be back to normal but now I can't change any art on my movies. I use to do this by pressing "i" on a movie but that no longer allows me to do this. Any suggestions?
I am not able to edit menu : ad : anyone have a fix with the new update
(2017-03-19, 06:05)Stevefp1971 Wrote: [ -> ]I am not able to edit menu : ad : anyone have a fix with the new update
What menu?
Cokeaholik
So if you go to configure <edit menu> ad it won't open does nothing . Also in same are can't ste label to more then one addon and most changes won't save
