Full Version: (SILVO) couple of questions...
Hi and thanks for this mod!
I gotta couple of questions if Any one wants to help Wink
I was just Wondering why i cant access the choose skin color?
I click on it and Nothing happens... Any idea?
Im using Silvo latest version installed from repo here on libreelec krypton o/s
When on a movie, hit "i" and info screen appears.
Is there a way to have a trailer button on there?
As of now i need to hit the plus + sign and select search trailers.
Talking about search trailers, it doesn't work well for me as,
Usually when im on info "i" screen and select "trailer"
It starts right away. Now it doesn't... It actually seems to perform
a YouTube search and Nothing and it shows all kind of results
instead of playing the trailer automatically..
What's up with that?
Is there a way to have the widgets fanart dimmed?
Looks nice like it is but its hard to read plots and stuff
depending on the movie fanart that appears in background.
When movie is playing, "i" info screen usually shows poster art,
Not anymore, there's a way have that again? It was a nice!
Thanks for the help!
Bug. Next update which I will post sometime today will fix it.
Next update will have a slight redesign for DialogVideoInfo and there is a trailer button.
If you have a trailer set in the ListItem.Trailer INFOlabel then it will play it but if not then it will search for one.
You shouldn't have an issue cause there is already an image behind the plot to see it better.
Can you post a pic of it being hard to see?
Poster is there as a fallback for when no logo or clearart is present.
Thanks for your reply mikeSilvo.
So for #1 and #2 i'll wait for the update. Thx.
#3 im not sure i understand this :/
#4 i'll come back with a picture, need to Capture one.
Some skins like artic zephyr dims the whole fanart.
Really love that feature / look
#5 im using video addons :/
Never saw poster as fallback...
Like in confluence poster always shows no matter what.
Anyway to have that option to force poster to show?
And any tutorial on how to see the dis art?
That too i Enabled it but...
Never appeared :/
Thanks for your work and patience!
Sorry for double post.
For #4, i think its my cheesy tv here the culprit.
Therefor on artic zéphyr its easier to read plots
because of dimmed widget fanarts...
I suggest to add a global widget fanart dim feature Wink
I actually have 3 issues..
#1 skin version 6.0.5 is not in repo... version i see is 6.0.4,,,??
#2 what did You mean by "a trailer set in the ListItem."
#3 discart impossible to get working. Discart enabled i Rightlist view
and Artwork Downloader i got from your recommanded section in skins settings.
What am i missing? I need more recommanded scripts?
Thx,!!
(2017-03-18, 16:12)eskro Wrote: [ -> ]#2 what did You mean by "a trailer set in the ListItem."
If your scraper searched for a trailer-URL and this trailer-URL is known in Kodi (via ListItem.Trailer) then Kodi will play the trailer. Otherwise Kodi will search, if it finds a trailer.
(2017-03-18, 16:12)eskro Wrote: [ -> ]#3 discart impossible to get working. Discart enabled i Rightlist view
Did you run ArtworkDownloader already? Without running it, you won't get any CDart etc.
How do you run Artwork Downloader?
Im. Not sure i get it.
I did go in its settings and set it to work in background..
And for trailers i didnt change Nothing regarding scraper settings.
Dont even know where to look for that?
Thx!
first disable running it in BG, so that you see, whats happening.
addons -> programm addons -> ArtworkDownloader -> run
and it should get some artwork.
But im using video addons and not local media.
Should still work?
