Hello, I downloaded a demo disc, but instead of it being 1 .mkv file let's say, it is all the files that would actually be in a blu ray disc. Can I get kodi to play the files like this?
So you have the a main folder which contains the folders BDMV and Certificate with other files and folders in those?
Yes Kodi can play it.
Yes exactly. So how do I go about playing it? What are the steps I need to take to do it? Will it play like a regular blu ray where there is a menu, and I can choose each chapter or will it just play all at once? Almost like just putting them together?
Thanks you very much for the info.
For Blu Ray rips if it was done correctly you can play the files yes.
Steps:
1- Rip BluRay
2- Make sure to put movie in a FOLDER that is named the EXACT NAME OF MOVIE with DATE like this: Spiderman (2003)
3- Add movie to KODI Library
4- Verify Movie shows in your library
5- Click on Movie
6- SHOULD BE a choice to open Bluray Menu or play movie directly from here.
IF NOT YOU SCREWED SOMETHING UP LOL
Sounds good, thanks guys. I will try it out.
It's not hard to do and KODI is awesome in the sense it'll allow you to play the movie OR go to the main menu.
If you want to simplify the process you could use Handbrake to rip the movie to .MKV
By ripping to .MKV the movie will just auto play the moment you click on the movie in KODI.
Yes, Handbrake is an app, a free app and it works wonderfully well.
