What do you do when you try to open Kodi for the first time and macOS comes back with "Kodi is damaged and cannot be opened. You should move it to the Trash."?
Thanks for any help in advance...
Dan
Probably a corrupted database, can you get us a
http://kodi.wiki/view/log_file ? See chapter 3 if Kodi wont run at all. Poste the link from pastbin here in the forum
<script src="//pastebin.com/embed_js/2TK0frah"></script>
Here you go. And if you see there is no Audio output I use USB headphones or BT remote speakers(which work fine on my Mac.)
thanks,
Dan
PS: I've shut off Gatekeeper. It is set to anywhere.
http://pastebin.com/embed_js/2TK0frah
The log is not complete, But nothing here points to a broken database. Argus tv is creating errors together with the audio device you mentioned
1. You already ran this command on terminal ? If not try this one first
sudo spctl --master-disable
2. As an option open if point one doesnt solve it enter terminal.app and enter
spctl --add --label "Kodi" /Applications/Kodi.app
I had this same issue. Try opening up from inside applications but holding control down when u click Kodi. Make sure in privacy you have selected anywhere for installed apps. Good luck,
Italbomber... That a did it. Thanks for the help, really appreciate it.
italbomber, I tried that as well, but on my systems preferences, I do not have the option to download from anywhere. Any other ideas?
(2017-03-22, 22:19)RhondaJ Wrote: [ -> ]italbomber, I tried that as well, but on my systems preferences, I do not have the option to download from anywhere. Any other ideas?
Open a terminal and enter
And look again at privacy settings
