2017-03-19, 19:08
Hi
This is subtitle addon for subscene.com. Current one needs maintanence, so i though it would be much way easir to re-write the addon with sublib.
I have tested in kodi 16 on both windows & android, seems to be working pretty solid. Please do test in vairous KODI versions and platforms, and if you face any issues post your debug log, i can patch the stuff.
WARNING:
When you install this addon, it will automatically update the current subscene from the official repo, I have contacted CrowleyAJ the developer of the older addon, but seems like he is not logging in for a while, and can not find his github or something else, if he has issues for this addon to superseed his, please contact me, i can change the name, but it just doesnt make any sense to keep 2 addons for the same service.
TLDR:
If you want to keep your original subscene addon, dont install this one.
INSTALLATION
Dowload biyik repo at:
https://raw.githubusercontent.com/hbiyik...-0.0.1.zip
to some place,
Go to
System -> Settings -> Addons -> Install From Zip File
Navigate to downlaoded zip file "repository.biyik-0.0.1.zip"
Goto
System -> Settings -> Addons -> Install From Repository
Huseyin Bıyık's KODI / XBMC Repo -> Subtitles -> subscene.com
Click install
WARNING:
TLDR:
INSTALLATION
to some place,
Go to
Goto
Click install
