I found a decent guide to get started with using TVHeadend:
http://forum.kodi.tv/showthread.php?tid=270385
however, I am stuck at adding the Network using US Broadcast channels.
While I continue to search - would anyone happen to have any suggestions?
TV Adapter:
Auvitek AU8522 QAM/8VSB FrontEnd : ATSC-C #0
Auvitek AU8522 QAM/8VSB FrontEnd : ATSC-T #0
The broad steps are (cut-and-paste from a previous post, so apologies if the laziness introduces any errors or omissions!):
1. Configuration -> DVB Inputs -> Networks
Create a network of the appropriate type here. You can have multiple networks of the same type, e.g. I have two DVB-T networks defined: one with HD muxes, one without, because one of my tuners doesn't support HD H.264.
2. Configuration -> DVB Inputs -> TV Adapters
Associate each of your tuners with the correct network. So, on mine, I have the HD DVB-T2 networks defined in Basic Settings -> Network on my HD tuners, but I have the SD network on the SD tuner and I have a DVB-S2 associated with my satellite tuners.
At this point, your tuners now know what networks to use: one network can appear on multiple tuners (many-to-one), and one tuner can have multiple networks.
3. Configuration -> DVB Inputs -> Muxes
This is where you'd manually add muxes or find the pre-defined ones you selected in step (1).
4. Configuration -> DVB Inputs -> Services
And this is where the services will appear as your tuners tune to the muxes based on the network you told them to look on.
So:
1. Define a network
2. Associate to an enabled tuner
3. Define muxes if not pre-populated
4. Scan for services
5. Map to channels
6. Define channel groups/adjust as needed
If that's no use, pop over to #hts on freenode and ask there - use something like kiwiirc if you don't normally use IRC.
(2017-03-20, 22:52)gjacob3412 Wrote: [ -> ]TV Adapter:
I don't know if it will matter any, but what I have is a:
Hauppauge WinTV-HVR 950q
http://www.hauppauge.com/site/products/d...r950q.html
Running SSH:
Quote: lsusb -v
Bus 001 Device 006: ID 2040:7200 Hauppauge
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2040 Hauppauge
idProduct 0x7200
bcdDevice 0.05
iManufacturer 1 (error)
iProduct 2 (error)
iSerial 10 (error)
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 267
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 5
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0300 1x 768 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x03fc 1x 1020 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0c00 2x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x1400 3x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 11 (error)
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 38
bInCollection 1
baInterfaceNr( 0) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0602 Digital Audio Interface
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front ®
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 3
iTerminal 0
bLength 8
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 3
bSourceID 1
bControlSize 1
bmaControls( 0) 0x01
Mute Control
iFeature 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 2 Streaming
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 2
bDelay 1 frames
wFormatTag 1 PCM
bLength 11
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 1 Discrete
tSamFreq[ 0] 48000
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0100 1x 256 bytes
bInterval 4
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0 Undefined
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
https://www.linuxtv.org/wiki/index.php/H...V-HVR-950Q
Quote:Making it Work
Firmware
In order to use the LinuxTV driver, you need to download and install the firmware for the xc5000. Some distributions already bundle the firmware in the official repositories. Ubuntu 9.10 (Karmic) includes it by default, Fedora 16+ includes it in the default linux-firmware package, and Debian Testing (Squeeze) includes it in the firmware-linux-nonfree package.
Kernel 2.6.30 and earlier:
wget http://www.steventoth.net/linux/xc5000/H...1_WHQL.zip
wget http://www.steventoth.net/linux/xc5000/extract.sh
sh extract.sh
cp dvb-fe-xc5000-1.1.fw /lib/firmware
Kernel 2.6.31 and later:
wget http://www.kernellabs.com/firmware/xc500...1.6.114.fw
mv dvb-fe-xc5000-1.6.114.fw /lib/firmware/
Note: Though the usual directory location in which the firmware file is placed is /lib/firmware, this may differ in the case of some distros; consult your distro's documentation for the appropriate location.
The firmware will be added lazily (on-demand) when you first use the driver.
Kernel 2.6.31 firmware issues
When running this kernel version, loading of the firmware takes very long, and prevents MythTV from working properly. To deal with this problem you can use xc5000's no_poweroff=1 module option, to prevent the device from sleeping (after which firmware has to be reloaded)
You can set no_poweroff this way:
cat /sys/module/xc5000/parameters/no_poweroff
0 # <--- default is automatic poweroff enabled
echo -n 1 > /sys/module/xc5000/parameters/no_poweroff
1 # <--- poweroff is now disabled
This will take effect when the module is reloaded.
Drivers
The xc5000 driver needed for this WinTV-HVR-950Q is already part of the latest Linux kernel (part of v4l-dvb drivers).
Analog support was merged into the mainline v4l-dvb tree on March 18, 2009.
Note: In the past, the HVR-950Q has had known issues with MythTV that prevent it from working. These should be fixed with the latest version. They were worked by the 950q maintainer (Devin Heitmueller). For more details, take a look at the KernelLabs blog for status updates: KernelLabs Blog
Wonder if this would help any,... though it states that latest kernel
Well, you haven't actually said what your problem is.
If your tuners aren't initialised properly, there'll be something in dmesg/syslog - they may appear in tvheadend, but won't work. That could well be a driver/firmware problem.
If they're initialising but you can't configure them, that's a tvheadend issue.
Log files (pastebin, please, not pasted here as above) would be helpful.
