When I go to quit Kodi 17.1 it just hangs and doesn't' close. I have to force close the application every time. I'm on a Mi Box 3. Can anyone else confirm this. Thanks!
It's probably something else on your kodi setup causing this.
Believe it or not i had the same issue and fixed it by deleting my favourites file.
Sent from my X15
Can confirm this bug with my FireTV 1.Gen.
Kodi 17.1 hangs up when I want to shut down Kodi.
Only way out of Kodi is return to FireTV Homescreen.
As I don't have any favourites there is nothing I can wipe.
*** Update ***
Removing the add-on SportsDevil together with Sportie resolves the Exit problems for me.
You can find more information here:
http://forum.kodi.tv/showthread.php?tid=310246
