2017-03-22, 18:45
2017-03-23, 05:08
Create a menu item for them
Skin Settings > Customise home menu
There is a shortcut for favourites under the common items node when you select the shortcut you want to use.
2017-03-23, 13:09
Thank you
2018-01-17, 03:12
It took me a bit to figure out, but I had to select a random favourite under "Custom Favourites" and then "Customise Edit path" and type "ActivateWindow(Favourites)"
(Wthout the "s of course.)
And then custom edit label and rename it to "Favourites" and Custom edit icon to the "favourites.png"
There you go.
There you go.
