2017-03-26, 10:07
Hi. I've bought an RF remote to control KODI on my Raspberry Pi 3. It's one of these that has normal remote control buttons on one side and a qwerty keyboard on the other. Everything works fine with the exception of the main 'OK' button on the 'normal remote' side - which is a pain. The 'Enter' button on the qwerty side of the remote works just fine though.
I've plugged the dongle into my laptop to check it's not just a hardware fault on the remote and it's fine - the OK button works.
How can I edit the KODI config file to say "When you hear the 'OK' button code, do what the 'Enter' button does" ?
Many thanks !
Many thanks !
