I have a SonyVaio laptop running Win 7 SP1. I have been running Kodi Jarvis 16.1 for a few months. Decided to upgrade to Krypton 17.1. Download and install went smoothly. At the finish I clicked on Run Kodi and clicked Finish. Nothing happened. So I went to the Kodi icon and clicked it. Nothing happened. I tried Run as administrator. Nothing. So I went to the Local Disk C, went to Programs (x86), Kodi, and went to Kodi .exe and clicked. Nothing.
Does anyone have a suggestion?
Having the same issue after upgrade as well, would love a resolution as well.
So I was just informed on the Facebook Kodi TV group by an Admin of the page that 17.1 only works on Windows 10
is this true
(2017-03-28, 15:10)pknoyes Wrote: [ -> ]I have a SonyVaio laptop running Win 7 SP1. I have been running Kodi Jarvis 16.1 for a few months. Decided to upgrade to Krypton 17.1. Download and install went smoothly. At the finish I clicked on Run Kodi and clicked Finish. Nothing happened. So I went to the Kodi icon and clicked it. Nothing happened. I tried Run as administrator. Nothing. So I went to the Local Disk C, went to Programs (x86), Kodi, and went to Kodi .exe and clicked. Nothing.
Same thing happen to me...I went back to Kodi 16 on Windows 7
Why not find out what happens with a
debug log (wiki) ?
simple on windows 10 go to cortana copy this and paste it ...
%APPDATA% select kodi then user data then you will see addons27 file. likely will work by doing this in search bar in windows 7.
Uninstalled 17.1..reinstalled Jarvis 16.1 working fine now..I'll wait until ALL bugs are worked out in 17.1 before I upgrade
(2017-03-29, 13:29)geohunt Wrote: [ -> ]Uninstalled 17.1..reinstalled Jarvis 16.1 working fine now..I'll wait until ALL bugs are worked out in 17.1 before I upgrade
...which will only happen if problems are being reported by users instead of just reverting. And even then there's no quarantees.
I'll have it delivered to you with a bouquet of flowers and a nice bottle of bubbly the moment the very last bug is worked out.
Don't hold your breath though.
(2017-03-29, 02:40)joshman79 Wrote: [ -> ]simple on windows 10 go to cortana copy this and paste it ...
This worked for me. I had the same problem, win10, 16.1 worked fine, install 17 and it does not start, no error messages.
Deleted the addons27 file in the Database folder in user data and now 17 works perfectly.
Thanks joshman79
