Full Version: Program EPG Icon on Channel List
It's possible to have the epg program icon while scrolling on the channel list (on the right side above the plot)?
Right now the channel appears on the left side in a small size and on the right side a little bigger, on the right side if the channel has epg should appear the program epg icon just like on the dialog "program information".
try going to Settings / PVR & Live TV - under menu / OSD you'll find the folder with channel icons
Also you may be able to do that in the PVR addon itself of on your backend device - depending on what you have
Depending on your guide source you can also have icon links as part of a XMLTV EPG source
