2017-03-30, 01:29
Good Day Everyone;
I am posting here because I have run into an issue with Kodi 17.1 that I have never experienced before. Last night I did a fresh install of Kodi 17.1 on Android. Once installed I opened Kodi; enabled unknown sources, and shut Kodi down again. I then tried to migrate the configuration I had previously put together for Kodi 17.0 on another box by replacing the addon, media, and userdata folders in the .kodi directory while Kodi was shut down; just like I have many times before with previous versions.
However; when I started Kodi back up again my splash image shows up, but the skin I use had not been applied, and none of the addons placed in the addon folder show up in Kodi. When I open the addon manager I can see that all the addons that were in the addon folder are there, but they are all disabled.
I should probably note; that I tried to do the same thing with my PC, and got the exact same results. Also; I did not experience this issue when working with Kodi 17.0.
My question is; does anybody know of a way to avoid this from happening? If not; is there a way that I could quickly enable all the addons at once without having to select each one in the addon manager and enable it manually?
I have quite a few things installed, and enabling them all manually would be a major inconvenience; especially if I have to do it on each machine I want to upgrade to Kodi 17.1
Any help would be greatly appreciated!
